Mensaje
por CARLOS A PAOLTRONI » Mié Dic 19, 2012 12:39 am
Instructions: Select a Load Type and Cartridge, then click Get Data to view results. You may also filter by Manufacturer, Bullet Weight and Powder.
Filters
Load Type
*Cartridge
Manufacturer
Bullet Weight
Powder
Cartridge: 30-06
Load Type: Rifle
Starting Loads
Maximum Loads
Bullet Weight (Gr.) Manufacturer Powder Bullet Diam. C.O.L. Grs. Vel. (ft/s) Pressure Grs. Vel. (ft/s) Pressure
110 GR. HDY SP Hodgdon H414 .308" 3.170" 57.0 3044 39,200 CUP 62.5 3268 46,900 CUP
110 GR. HDY SP Winchester 760 .308" 3.170" 57.0 3044 39,200 CUP 62.5 3268 46,900 CUP
110 GR. HDY SP Hodgdon CFE 223 .308" 3.170" 55.6 3224 50,600 PSI 59.0 3370 56,400 PSI
110 GR. HDY SP Hodgdon Varget .308" 3.170" 55.0 3308 44,400 CUP 59.0 3452 48,500 CUP
110 GR. HDY SP IMR IMR 4320 .308" 3.170" 57.0 3285 49,400 PSI 60.5 3470 58,100 PSI
110 GR. HDY SP IMR IMR 4064 .308" 3.170" 55.0 3263 47,900 PSI 58.5 3453 56,400 PSI
110 GR. HDY SP Winchester 748 .308" 3.170" 52.7 3320 47,000 CUP
110 GR. HDY SP Hodgdon BL-C(2) .308" 3.170" 54.0 3108 36,200 CUP 60.0 3396 45,000 CUP
110 GR. HDY SP IMR IMR 4895 .308" 3.170" 56.0 3303 48,200 PSI 59.8 3505 57,300 PSI
110 GR. HDY SP Hodgdon H335 .308" 3.170" 50.0 3168 43,500 CUP 55.5 3367 48,100 CUP
110 GR. HDY SP Hodgdon H4895 .308" 3.170" 51.0 3155 39,000 CUP 57.0 3431 49,300 CUP
110 GR. HDY SP IMR IMR 8208 XBR .308" 3.170" 52.6 3223 46,200 PSI 56.0 3415 57,500 PSI
110 GR. HDY SP IMR IMR 3031 .308" 3.170" 51.0 3252 47,200 PSI 54.9 3471 57,800 PSI
110 GR. HDY SP Hodgdon Benchmark .308" 3.170" 51.5 3242 45,600 CUP 55.0 3396 49,800 CUP
125 GR. SIE SP Hodgdon H414 .308" 3.150" 57.0 2952 40,300 CUP 62.5 3181 46,700 CUP
125 GR. SIE SP Winchester 760 .308" 3.150" 57.0 2952 40,300 CUP 62.5 3181 46,700 CUP
125 GR. SIE SP IMR IMR 4007 SSC .308" 3.150" 55.0 2881 42,500 PSI 60.0C 3136 53,000 PSI
125 GR. SIE SP Hodgdon CFE 223 .308" 3.150" 54.5 3081 53,000 PSI 58.0 3212 58,900 PSI
125 GR. SIE SP Hodgdon Varget .308" 3.150" 54.0 3159 45,500 CUP 57.2 3267 49,500 CUP
125 GR. SIE SP IMR IMR 4320 .308" 3.150" 54.0 3125 49,100 PSI 57.5 3307 57,900 PSI
125 GR. SIE SP IMR IMR 4064 .308" 3.150" 53.0 3129 47,400 PSI 56.5 3334 58,000 PSI
125 GR. SIE SP Winchester 748 .308" 3.150" 51.0 3060 46,000 CUP
125 GR. SIE SP Hodgdon BL-C(2) .308" 3.150" 53.0 3117 38,000 CUP 58.7 3273 48,700 CUP
125 GR. SIE SP IMR IMR 4895 .308" 3.150" 53.0 3137 47,800 PSI 57.2 3331 56,800 PSI
125 GR. SIE SP Hodgdon H335 .308" 3.150" 49.0 3046 43,000 CUP 54.0 3228 49,300 CUP
125 GR. SIE SP Hodgdon H4895 .308" 3.150" 48.0 2977 41,400 CUP 53.7 3229 49,300 CUP
125 GR. SIE SP IMR IMR 8208 XBR .308" 3.150" 51.5 3100 50,400 PSI 54.7 3243 57,400 PSI
125 GR. SIE SP IMR IMR 3031 .308" 3.150" 49.0 3091 47,100 PSI 52.8 3298 58,400 PSI
125 GR. SIE SP Hodgdon Benchmark .308" 3.150" 49.0 2996 40,700 CUP 52.0 3178 48,700 CUP
130 GR. SPR HP Hodgdon H414 .308" 3.060" 56.0 2862 40,600 CUP 62.0 3157 48,700 CUP
130 GR. SPR HP IMR IMR 4007 SSC .308" 3.060" 54.0 2888 45,300 PSI 59.0C 3140 57,100 PSI
130 GR. SPR HP Hodgdon CFE 223 .308" 3.060" 54.0 3004 52,300 PSI 57.4 3145 59,100 PSI
130 GR. SPR HP Hodgdon Varget .308" 3.060" 49.0 2979 41,300 CUP 53.5 3154 48,400 CUP
130 GR. SPR HP IMR IMR 4320 .308" 3.060" 51.0 3094 55,600 PSI 54.5 3197 57,700 PSI
130 GR. SPR HP IMR IMR 4064 .308" 3.060" 51.0 3070 49,500 PSI 54.5 3243 58,200 PSI
130 GR. SPR HP Hodgdon BL-C(2) .308" 3.060" 52.0 2936 36,600 CUP 58.0 3179 48,300 CUP
130 GR. SPR HP IMR IMR 4895 .308" 3.060" 51.0 3074 50,800 PSI 54.7 3234 57,800 PSI
130 GR. SPR HP Hodgdon H335 .308" 3.060" 48.0 2912 39,600 CUP 53.5 3158 48,600 CUP
130 GR. SPR HP Hodgdon H4895 .308" 3.060" 48.0 2927 38,600 CUP 53.1 3144 46,100 CUP
130 GR. SPR HP IMR IMR 8208 XBR .308" 3.060" 49.1 3021 52,100 PSI 51.7 3126 56,900 PSI
130 GR. SPR HP IMR IMR 3031 .308" 3.150" 47.0 3010 49,500 PSI 50.3 3176 58,300 PSI
130 GR. SPR HP Hodgdon Benchmark .308" 3.060" 48.0 2986 44,900 CUP 51.0 3107 48,700 CUP
150 GR. NOS BT Hodgdon Suprform .308" 3.250" 60.0 2850 43,100 PSI 65.0C 3072 53,000 PSI
150 GR. NOS BT Hodgdon H4350 .308" 3.250" 56.0 2792 37,100 CUP 62.0C 3068 48,400 CUP
150 GR. NOS BT Hodgdon H414 .308" 3.250" 54.0 2753 40,500 CUP 60.0 2992 48,600 CUP
150 GR. NOS BT IMR IMR 4350 .308" 3.250" 54.0 2745 47,400 PSI 58.0C 2942 57,200 PSI
150 GR. NOS BT Winchester 760 .308" 3.250" 54.0 2792 40,500 CUP 60.0 2992 48,600 CUP
150 GR. NOS BT IMR IMR 4007 SSC .308" 3.250" 52.4 2799 49,300 PSI 55.3 2972 58,000 PSI
150 GR. NOS BT Hodgdon H380 .308" 3.250" 53.0 2798 40,200 CUP 59.0 3005 45,900 CUP
150 GR. NOS BT Hodgdon CFE 223 .308" 3.250" 50.1 2763 50,500 PSI 54.2 2942 58,600 PSI
150 GR. NOS BT Hodgdon Varget .308" 3.250" 47.0 2808 42,600 CUP 51.0 2975 50,000 CUP
150 GR. NOS BT IMR IMR 4320 .308" 3.250" 49.0 2850 51,600 PSI 52.3 3016 58,000 PSI
150 GR. NOS BT IMR IMR 4064 .308" 3.250" 47.0 2743 49,000 PSI 51.0 2928 58,600 PSI
150 GR. NOS BT Winchester 748 .308" 3.250" 48.0 2810 46,000 CUP
150 GR. NOS BT Hodgdon BL-C(2) .308" 3.250" 49.0 2759 39,700 CUP 54.0 2962 48,600 CUP
150 GR. NOS BT IMR IMR 4895 .308" 3.250" 49.0 2856 49,400 PSI 53.0 3009 56,700 PSI
150 GR. NOS BT Hodgdon H335 .308" 3.250" 47.0 2785 42,500 CUP 51.5 2982 49,200 CUP
150 GR. NOS BT Hodgdon H4895 .308" 3.250" 46.0 2806 44,400 CUP 51.0 2976 48,500 CUP
150 GR. NOS BT IMR IMR 8208 XBR .308" 3.250" 47.0 2797 50,500 PSI 50.0 2935 58,400 PSI
150 GR. NOS BT IMR IMR 3031 .308" 3.250" 43.0 2697 47,600 PSI 46.7 2887 59,300 PSI
150 GR. NOS BT Hodgdon Benchmark .308" 3.250" 46.5 2792 44,600 CUP 49.5 2944 49,300 CUP
150 GR. NOS BT IMR Trail Boss .308" 3.250" 13.3 1061 14,700 PSI 19.0 1477 26,400 PSI
150 GR. NOS E-TIP Hodgdon H4350 .308" 3.300" 54.0 2747 47,000 PSI 57.8C 2927 57,700 PSI
150 GR. NOS E-TIP Hodgdon H414 .308" 3.300" 53.0 2779 49,300 PSI 57.0 2945 57,100 PSI
150 GR. NOS E-TIP IMR IMR 4350 .308" 3.300" 54.0 2744 48,800 PSI 57.5C 2930 57,300 PSI
150 GR. NOS E-TIP Winchester 760 .308" 3.300" 53.0 2779 49,300 PSI 57.0 2945 57,100 PSI
150 GR. NOS E-TIP IMR IMR 4007 SSC .308" 3.300" 52.0 2729 49,900 PSI 55.3C 2901 57,800 PSI
150 GR. NOS E-TIP Hodgdon H380 .308" 3.300" 53.0 2763 50,400 PSI 57.0 2921 57,300 PSI
150 GR. NOS E-TIP Hodgdon CFE 223 .308" 3.300" 49.0 2715 47,600 PSI 53.2 2927 58,600 PSI
150 GR. NOS E-TIP Hodgdon Varget .308" 3.300" 46.0 2697 49,900 PSI 49.5 2860 58,000 PSI
150 GR. NOS E-TIP IMR IMR 4320 .308" 3.300" 48.0 2695 48,400 PSI 52.0 2897 58,100 PSI
150 GR. NOS E-TIP IMR IMR 4064 .308" 3.300" 47.0 2714 48,700 PSI 51.0 2926 59,500 PSI
150 GR. NOS E-TIP Winchester 748 .308" 3.300" 48.0 2704 48,000 PSI 51.5 2859 55,400 PSI
150 GR. NOS E-TIP Hodgdon BL-C(2) .308" 3.300" 50.0 2777 51,300 PSI 53.5 2915 57,900 PSI
150 GR. NOS E-TIP IMR IMR 4895 .308" 3.300" 47.0 2717 50,000 PSI 50.8 2900 58,700 PSI
150 GR. NOS E-TIP Hodgdon H335 .308" 3.300" 44.0 2671 51,600 PSI 48.0 2842 59,200 PSI
150 GR. NOS E-TIP Hodgdon H4895 .308" 3.300" 43.0 2658 49,000 PSI 47.5 2863 59,700 PSI
150 GR. NOS E-TIP IMR IMR 8208 XBR .308" 3.300" 44.0 2677 50,100 PSI 47.7 2838 58,500 PSI
150 GR. NOS E-TIP IMR IMR 3031 .308" 3.300" 43.0 2644 47,600 PSI 46.0 2811 56,600 PSI
150 GR. NOS E-TIP Hodgdon Benchmark .308" 3.300" 44.0 2631 46,400 PSI 48.0 2850 58,600 PSI
155 GR. SIE HPBT Hodgdon Suprform .308" 3.225" 59.0 2843 43,400 PSI 65.2C 3125 58,800 PSI
155 GR. SIE HPBT Hodgdon H4350 .308" 3.225" 56.0 2757 36,000 CUP 62.0C 3038 47,500 CUP
155 GR. SIE HPBT Hodgdon H414 .308" 3.225" 54.0 2732 39,600 CUP 60.0 2956 46,200 CUP
155 GR. SIE HPBT IMR IMR 4350 .308" 3.225" 56.0 2784 45,800 PSI 60.0C 2959 53,800 PSI
155 GR. SIE HPBT IMR IMR 4007 SSC .308" 3.225" 53.0 2766 48,800 PSI 57.2 2964 58,800 PSI
155 GR. SIE HPBT Hodgdon H380 .308" 3.225" 53.0 2789 40,100 CUP 59.0 3009 47,800 CUP
155 GR. SIE HPBT Hodgdon CFE 223 .308" 3.225" 49.2 2744 52,200 PSI 52.3 2879 59,500 PSI
155 GR. SIE HPBT Hodgdon Varget .308" 3.225" 48.0 2822 44,600 CUP 50.7 2958 48,800 CUP
155 GR. SIE HPBT IMR IMR 4320 .308" 3.225" 49.0 2823 50,800 PSI 53.0 2976 57,900 PSI
155 GR. SIE HPBT IMR IMR 4064 .308" 3.225" 49.0 2811 46,800 PSI 53.0 3005 58,800 PSI
155 GR. SIE HPBT Hodgdon BL-C(2) .308" 3.225" 49.0 2723 38,800 CUP 54.0 2912 46,300 CUP
155 GR. SIE HPBT IMR IMR 4895 .308" 3.225" 50.0 2851 49,800 PSI 53.8 3010 58,000 PSI
155 GR. SIE HPBT Hodgdon H335 .308" 3.225" 47.0 2776 42,200 CUP 51.5 2943 48,800 CUP
155 GR. SIE HPBT Hodgdon H4895 .308" 3.225" 46.0 2752 41,200 CUP 51.0 2925 45,600 CUP
155 GR. SIE HPBT IMR IMR 8208 XBR .308" 3.225" 46.1 2747 50,400 PSI 49.0 2869 57,500 PSI
155 GR. SIE HPBT IMR IMR 3031 .308" 3.225" 46.0 2779 47,600 PSI 49.0 2944 58,600 PSI
155 GR. SIE HPBT Hodgdon Benchmark .308" 3.225" 46.5 2779 40,500 CUP 49.5 2916 49,400 CUP
165 GR. HDY GMX Hodgdon Hybrid 100V .308" 3.225" 52.5 2653 48,600 PSI 56.7C 2818 56,700 PSI
165 GR. HDY GMX Hodgdon H4350 .308" 3.225" 51.0 2587 48,600 PSI 55.4 2781 59,200 PSI
165 GR. HDY GMX Hodgdon H414 .308" 3.225" 50.0 2656 52,400 PSI 53.1 2773 58,500 PSI
165 GR. HDY GMX IMR IMR 4350 .308" 3.225" 52.0 2546 46,700 PSI 56.6 2770 58,200 PSI
165 GR. HDY GMX Winchester 760 .308" 3.225" 50.0 2656 52,400 PSI 53.1 2773 58,500 PSI
165 GR. HDY GMX IMR IMR 4007 SSC .308" 3.225" 49.0 2594 48,700 PSI 52.4 2762 57,600 PSI
165 GR. HDY GMX Hodgdon H380 .308" 3.225" 52.0 2652 52,700 PSI 56.0 2788 57,300 PSI
165 GR. HDY GMX Hodgdon CFE 223 .308" 3.225" 43.9 2531 51,200 PSI 46.7 2672 57,500 PSI
165 GR. HDY GMX Hodgdon Varget .308" 3.225" 44.5 2526 46,600 PSI 48.3 2724 59,000 PSI
165 GR. HDY GMX IMR IMR 4320 .308" 3.225" 45.6 2515 45,800 PSI 49.6 2731 58,700 PSI
165 GR. HDY GMX IMR IMR 4064 .308" 3.225" 44.4 2510 44,900 PSI 48.2 2729 58,600 PSI
165 GR. HDY GMX Hodgdon BL-C(2) .308" 3.225" 43.9 2511 49,200 PSI 47.5 2706 58,800 PSI
165 GR. HDY GMX IMR IMR 4895 .308" 3.225" 44.4 2535 45,100 PSI 47.8 2757 58,400 PSI
165 GR. HDY GMX Hodgdon H4895 .308" 3.225" 43.4 2595 50,300 PSI 46.7 2712 57,100 PSI
165 GR. HDY GMX IMR IMR 8208 XBR .308" 3.225" 43.2 2572 50,800 PSI 47.0 2717 58,300 PSI
165 GR. HDY GMX IMR IMR 3031 .308" 3.225" 41.0 2510 46,400 PSI 44.1 2685 58,100 PSI
165 GR. SIE SPBT Hodgdon Suprform .308" 3.300" 55.0 2724 45,100 PSI 61.0 2972 58,800 PSI
165 GR. SIE SPBT Hodgdon Hybrid 100V .308" 3.300" 53.0 2648 46,000 PSI 57.0C 2801 52,800 PSI
165 GR. SIE SPBT Hodgdon H4350 .308" 3.300" 53.0 2678 38,400 CUP 59.0 2938 49,400 CUP
165 GR. SIE SPBT Hodgdon H414 .308" 3.300" 51.0 2678 41,900 CUP 56.5 2877 49,700 CUP
165 GR. SIE SPBT IMR IMR 4350 .308" 3.300" 56.0 2746 48,100 PSI 60.0C 2934 57,600 PSI
165 GR. SIE SPBT Winchester 760 .308" 3.300" 51.0 2678 38,400 CUP 56.5 2877 49,700 CUP
165 GR. SIE SPBT IMR IMR 4007 SSC .308" 3.300" 54.3 2800 54,300 PSI 55.9 2867 58,300 PSI
165 GR. SIE SPBT Hodgdon H380 .308" 3.300" 51.0 2669 41,700 CUP 56.5 2892 50,000 CUP
165 GR. SIE SPBT Hodgdon CFE 223 .308" 3.300" 46.5 2612 52,900 PSI 49.5 2731 58,700 PSI
165 GR. SIE SPBT Hodgdon Varget .308" 3.300" 47.0 2726 44,500 CUP 50.5 2873 49,700 CUP
165 GR. SIE SPBT IMR IMR 4320 .308" 3.300" 48.0 2727 50,700 PSI 51.2 2869 58,600 PSI
165 GR. SIE SPBT IMR IMR 4064 .308" 3.300" 49.0 2752 50,400 PSI 52.5 2901 58,900 PSI
165 GR. SIE SPBT Hodgdon BL-C(2) .308" 3.300" 46.0 2608 41,200 CUP 51.0 2805 49,800 CUP
165 GR. SIE SPBT IMR IMR 4895 .308" 3.300" 49.0 2768 50,500 PSI 52.0 2888 57,200 PSI
